talbot wrote:One caution. I patched some major dings at the keel near the prow with Marine-Tex, an epoxy. Gel-coat will not adhere to epoxy.
MarcCram wrote:I guess the moral with 2-part resins is mix until you can't mix anymore and then mix again, and again.
GreenLake wrote:Are you sure it's epoxy? If so, it's not only the mixing, but also the measuring.
