boat going into slip for summer
Postby smithel » Mon Apr 20, 2009 4:54 pm
im going to be putting my daysailer in a slip this summer, my question is, should i put the bottom plug in near the transom, to keep water from coming in, or should i leave it out so rainwater would exit the boat, i thought the boat has to be moving to remove water that is inside ?
smithel
bilge drain
Postby Roger » Mon Apr 20, 2009 10:54 pm
The bottom plug near the transom, (bottom of the transom is the bilge drain. Keep is closed whenever the boat is in the water.The hole above it, just above the waterline is the mooring drain. Rainwater fills the cockpit to the waterline, then it drains out this hole. The dePersia bailer is the plug in the bottom of the hull at the back, (not the transom) and it will drain (poorly) only when the boat is moving. Keep this one closed at the mooring as well.
