Tiller Question
Tiller Question
Postby dheritage » Tue Apr 28, 2009 12:45 pm
Could anyone tell me whether the rudder assembly from a Sprite would work on DS II? They look close.
D.Heritage
Kingston MA
dheritage
Postby redtailseven » Fri May 01, 2009 12:05 am
Just try to put it on. If the pintles don't match. consider moving one of them up or down. If the tiller is too low, raise the rudder, etc. You might have move both pintles to get it to work. Check the size of the rudder (the part in the water). Its not rocket science unless your racing. If the sizes are close, it should work just fine. The length of the tiller may be an issuse, you should sail it first. If its too short, cut it, too long make a longer one using the other as a pattern and splice or bolt something on.
Have fun with this little puzzle.
greg
Redtail 7 honors the Tuskeegee Airmen
redtailseven
Postby dheritage » Sun May 03, 2009 9:22 pm
Thanks! My biggest concern was the size. I'll give it a try.
dheritage
