My Trailer Motor Mount and Mast Crutch
Like a few others I didn't trust my outboard hanging off my transom while I trailered, nor did I like the idea of it it sliding around in the boat. I ended up throwing it in the back of my SUV, that lasted 1 trip the smell of 2 stroke was just too much for the admiral to take.
I went to the drawing board and came up with this setup. I used all PT lumber since it will be outside all the time.
I took at 10 foot 2X12 plank and cut it into 4 pieces only 3 are used.
I roughly measured the length of OB shaft plus the jack bracket with 2" extra added in for strength. In my case it was 28" I wanted to be sure that the prop was just about even with the bottom of the trailer tongue and didn't hang lower for worry of damage.
I took off the jack and used the starboard side mounting bracket as a template leaving at least 2" of wood below the bottom hole. I drilled the 4 holes and used longer grade 8 bolts (5-6" from what I remember). I reassembled the jack with the board added in. I wasn't happy that it wiggled up high so I added in 2 shorter boars to help stabilize it.
Be sure to measure the depth of your OB mounting clamps and cut the middle board shorter than that measurement. In my case 17". For looks I cut the third board at 13"
Now line up the 2 shorter board with the longer board and mark the location of the bolts on the shorter boards. Only the top 2 bolts will be marked. You will need to notch the boards so they straddle the bolts. Your goal is to get both boards to to sit flush on the top 4X4 aluminum piece of the trailer.
I loosened up the top 2 jack bolts and screwed the middle and longest board together, then the shortest to middle. The I tool some long screws and went thru all 3 boards. I tightened up the jack bolts and this thing was super solid.
I added in a ratchet strap to go around the OB to prevent it from rising up off the base. I figured the less it moves the safer.
Sorry it's sideways you get the idea
Now that the motor was secure I turned my attention to the mast. I added in 2X4 that I cut to 53". I can't remember why I chose that length but it gets the mast off the deck. I cut 2 feet of garden hose split it down the middle and looped that over the 2x4 to act as bumper to protect the mast. I used another ratchet strap, attaching the ratchet by the tail end to the wood with screws and trimmed the male end so that it looped over the top of the mast and was secured on the other side. When I put the mast on down I use the cunningham cleat ( on the mast) as a stopper on the boat side of the 2x4. I have just enough room to open the hatch of my truck and clear the mast.
Now to the stern:
I assembled this "t" out of some 1X4 and added a "V" on top to hold the mast in place Approx cut to 24 and 20. I used some brackets I had lying around to make the V and covered it with garden hose to protect the mast. I just eyeballed the height and wasn't concerned about keeping the mast level I just wanted to keep it off the deck and as low as possible to keep a low profile while trailering.
I drilled a hole in the T and ran a rope thru it. I take that rope thru the transom drain, around the plank and tie up a few knots and its super secure.
The blue things are ladder bumpers that I had under the workbench.
You'll get the idea here, I just laid the mast down for the pic I didn't want to de-rig the whole boat. I'll add that picture when I'm ready to trailer it down. Oh and the green bottle... thats for the buoyancy project. More on that to come.
Please let me know your thoughts of if you end up building this yourself. For me this started out as a weeknight project to make a mast crutch and ended up with this creation. I didn't have plans, I had some lumber and a saw and ended up with this. Totally not my super anal over analyze everything style but I had the wind with me that day and ran with it.
