Wiring lights & motor
After 20 yrs of rowing the DSII, I finally got an electric motor (Minn Kota, 30lbs thrust). As long as I am lugging around a 40lb battery, I figure I might as well install lights. I read the posts on battery placement. More questions:
1. Is the cuddy too far aft to mount verticle sidelights? It would be so much easier than working in the forepeak. I figure I could cant the bases if necessary to get the required visibility aft.
2. If I'm putting lights and motor on the same battery, do I need to install a panel?
3. Besides sidelights on the cuddy, I'm thinking of a socket for the motor port side aft and a socket for the stern light starboard aft (opposite the motor mount). Toggle switch for the lights on the main bulkhead. Battery box would be just forward of the mast on the cuddy floor. Any concerns with this design?
4. Battery charging. At my marina, most people use solar (there is no power to the individual slips). I imagine having a receptacle somewhere on the cuddy that is already wired to the terminals (maybe through a regulator), where I can plug in the panel. Does that make sense? Where would you place such a receptacle.
I'm aiming for a set up that is low profile. Except for the fixed navigation lights on the cuddy, everything else strips away so the boat is an unencumbered sailboat most of the time. When the motor, lights, and charger are used, they are easy to deploy. At the same time, the electrical project doesn't negate last year's project, which involved making the cuddy near-watertight with a solid hatch and seals around the mast.
