Brought my DS2 in from the mooring to drain the remnants of Issac from under the hull liner. It was the usual pain, yawing in both directions but more into the wind (90 degrees), S 5kts, than away from the wind (20-30 degrees).
No rudder, CB up (beaching), going slowly, and a bridle attached to each bow cleat. Same problem going out to the mooring earlier this summer using the bow eye.
I wondered if the extra water was making it difficult but the earlier attempt was when the boat first went into the water. What does it take to get a DS to tow in a straight line?
Cal
