Sail Number
Sail Number
Postby Rakozy » Sun Aug 02, 2015 10:24 am
Having just purchased a 1982 DS II, there is no sail numbers on my main sail.
How do I determine what my specific sail number is for my boat? Is it part of the serial number on the Transom?
Rakozy
Rakozy
Re: Sail Number
Postby jeadstx » Sun Aug 02, 2015 10:32 am
It should be part of the HIN on the transom.
Re: Sail Number
Postby Rakozy » Sun Aug 02, 2015 4:39 pm
The serial number on my transom is: XDY12076M82J-D
So you think my sail number would be 12076 ?
How would I confirm this to be sure?
Rakozy
Rakozy
Re: Sail Number
Postby GreenLake » Sun Aug 02, 2015 4:46 pm
No need to confirm. But as you are not certain:
The Hull Number Index shows that it falls in the range for a DSII, and given the range of dates and numbers, the 12076 is more than plausible.
Re: Sail Number
Postby jeadstx » Sun Aug 02, 2015 5:36 pm
I looked at my DS II, the sail number is the 12076. My sail number is right after the "XDY".
Re: Sail Number
Postby TIM WEBB » Mon Aug 03, 2015 9:20 pm
This link will tell you all about HINs post-Nov 1 1972:
http://www.boatsafe.com/nauticalknowhow/hin.htm
I believe that hull # = sail # on Daysailers built from then on out, and I think the hull # index bears this out ... ?
Re: Sail Number
Postby GreenLake » Tue Aug 04, 2015 2:52 am
TIM WEBB wrote:I believe that hull # = sail # on Daysailers built from then on out, and I think the hull # index bears this out ... ?
You can remove the qualifiers and up the confidence level of that statement. (Read the early posts in this forum)
