Replacing Transom Plug Brass Tube (Drain Tube)
The DSII has two drain plugs on the transom as well as a self bailer. The lower plug drains the space between the hull liner (floor) and the hull, while the upper plug would drain the cockpit. The rubber expansion plug was stuck in the brass tube, so I tapped it out....out came the brass tube with it! I replaced it with a new one and thought I'd post a series of photos of how I did it.
The "readers digest" version is that the tube was in 2 parts pushed in from either side of the transom (BTW, not a great set up anyway - the seam between the two halves would eventually let water migrate into the transom and possibly rot the wood - this did not happen in this case!). One half came out with the stuck rubber plug, the outer half I cut a slot with a hack saw blade and encouraged it out with a punch and some light tapping (you can see the remains). The hole was a bit dirty, so I cleaned it out with sandpaper and a round file. I found that the new tube (see below for part number) didn't seat fully due to the radius on the tube and the squared sides of the hole in the transom. I put a similar radius on the transom with a little round grinding stone on a drill. The replacement tube is cut to 1/4" longer than the hole. Then coated the hole and the tube with bedding compound and used a special tool to compress the tube and form the outside flanges. It's about a 30 minute job (and that's going slow); so not a big deal at all! I suppose if the tube was really stuck in the transom it would be a bit more difficult.
The parts I used were:
Moeller Drain Tubes; MOE-021003-400D -- Brass - 1 x 4 inch (trim to fit) -- about $8 each
Moeller Marine Flanging Tools; MOE-2070000 -- 1 inch O.D. Flanging Tool -- about $41 each (good to borrow one if you have a friend!)
Sikaflex-291 Adhesive and Sealant -- about $18 (caulking gun tube, hopefully you have some around the shop - very little is needed!)
Here's a link to some photos of the removal and installation.
https://photos.app.goo.gl/DkxrjQVfU1wamkdq8
