by jib alone?
Went for a sail yesterday at the lake where I keep the boat. There was a steady, what I would guess was a, 'gentle breeze' with stronger gusts. I ended up not going out and taking a swim instead.
I wasn't sure what to do. Normally, I use the mainsail only when single-handing as the jib sheets are too far forward to make for a comfortable time of it. There are no reef points on the main and it has the infamous 'roller reefing' built into the boom. I didn't want to go out with a full main and had never used the roller reefing feature. And, trying to employ it before heading out seemed a tall task, where the main would have to be hoisted all the way before lowering it enough to roll what you need onto the boom, against a wind trying to prevent it. Then, if you succeed, the mid-boom sheeting has to be reattached to the end of the boom. I imagine that would still make it possible to control the main from that location although doesn't that mean the main sheet runs from the jammer on the centerboard trunk to the boom's end in a diagonal line from low to high? And is that in the way of the helmsman as he moves around?
Then I wondered if the jib alone could be used (don't have roller furling) and where should the centerboard be positioned in that case (?). When using the main alone I pull the centerboard handle (DS1 - 1961) about half way back and she seems well balanced and sails fine.
Thoughts, advice?
navahoIII
'Annie'
Thoughts, advice?
navahoIII
'Annie'
