Torqeedo
I've owned a Torqeedo 1003 long shaft for about eight months, and finally got a chance last week to try it this week on Lake Tahoe. (I wouldn't have spent the money, but it was free; long story, which I'll tell if anyone's interested.)
Some good points, some bad points.
Performance: The top speed reading steadied out at 5.6 mph on the integral GPS. That's with about 500 pounds of people and stuff in the boat. Indicated remaining time at that speed, with the battery at 87%, varied from 0.3 to 0.7 hours. (And by the way, it dropped from 98% to 87% in about a half hour of intermittent, mostly low-speed operation.) I'll be able to test it again later this year, and this time I'll be close enough to the marina that I'll be able to hold it at full throttle for a while to see if the top speed increases or the time remaining reading steadies out.
Range: Short at high speed (see above). At 0.9 mph, 17 hours. At 1.7 mph, 10 hours. At 2.5 mph, 4 hours. At 3.5 mph, which you need to push through the powerboat wakes on Tahoe, 2 hours. (These are approximate averages; the speed and time indicators kept jumping around). The indicated ranges on the Torqeedo website are pretty close to what I got, but my boat’s weight was nowhere near the 1.5 tons they mention as the upper capacity limit for the 1003. It's possible to charge the motor’s battery while the motor is in use, using 12-volt batteries and an inverter. This seems like a good use for my now-redundant trolling motor batteries, so I hope to get that set up before the next sail to find out how much range the auxiliary batteries add.
Weight: About 30 pounds, 10 pounds of battery and 20 pounds of motor. It's very easy to separate the battery from the motor, and the battery has a built-in carrying handle, so installing and removing the motor is a snap. It’s also extremely easy to tilt and lock up out of the way when you’re ready to sail.
Steering: It’s impressively easy to steer the boat using just the Torqeedo. On our way to the marina launch ramp to go home, I didn’t install the rudder and just used the motor to steer. It doesn’t have the infamous “prop walk” problem, where using the motor in reverse makes the boat go sideways. (A friend of ours with a Pearson 323 uses this to get out of his marina, spinning the boat like a top to point it in the right direction.) Sitting on the transom, I was easily able to back out of the slip, turn the boat facing the right way, and motor out to the ramp. It’s easy to make sharp turns, it’s easy to make gradual turns, and it’s easy to move from sharp to gradual and back.
Sound: It’s louder that I expected, maybe as loud as a modern well-muffled outboard that blows its exhaust out underwater. Even at 0.9 mph, it’s much louder than a 55-pound thrust trolling motor at full throttle, with a steady “thrum-thrum” instead of the trolling motor’s constant faint hum. Think of a sewing machine on steroids. No way anyone’s using it as a trolling motor; the fish would head elsewhere.
Reverse/kick-up lock: The motor is free to kick up when it hits something while the boat is moving forward, unless you press the convenient tab that locks it in the down position, which allows you to move quickly in reverse. If you forget to push the tab and use reverse anyway, you’ll be fine until about 0.5 mph, at which point the motor will rise up until it runs out of water. Unlike a trolling motor, though, it won’t try to twist itself off the transom because the shaft is free to swivel, so unless anyone happens to be watching closely, you wont embarrass yourself.
Steering lock: There’s a small plastic pin that fits into the motor and shaft to lock them in the straight-ahead position. Not much use on a Daysailer, since the curve of the transom places the motor at an angle away from straight ahead.
Shaft length: A long-shaft model is a good idea. That’s what I have, and it’s just about long enough. A short-shaft model would probably cavitate, so you’d have to hang it off of the stern on a mount that could be lowered. Direct clamping to the transom is a lot easier, and the tiller is easy to reach.
