EP Carry - Electric Paddle Review
Hi Folks:
So, I went ahead and sprang for the EP Carrry electric outboard. Figured I'd give my own review, for what it's worth. If you're not familiar with the little engine, here it is:
https://www.electricpaddle.com/ep-carry-boat-motor.html
Basically, it is EXACTLY what it says on the tin: about as powerful (not very but just enough), convenient (very!), and maneuverable (quite) as using a paddle... without the annoying kneeling on the bow and paddling bit. For the Daysailer, I think it's ideal. I have a brand new-to-me ancient DS1, see thread entitled #37 in the DS1 section. Yesterday, I took her to my local lake for a mast-less test run - just put her in and putt-putt around for a while and see how everything works. And to see if the great big drain plug behind the centerboard holds...
Everything went smoothly, the EP motor was dead simple and effortless to screw onto the stern at the ramp dock. I bought a long-shaft EP, so the cavitation plate was about 8 inches underwater, perfect! It's ridiculously easy to start - pop the magnetic "key" into the hole into the throttle and then turn the big knob. It doesn't turn much, but has some notches so that you can judge the throttle - two notches is full throttle, 1 notch is half, use your eye for 1/4 and 3/4 throttle and you really don't need to be more exact than that. Clockwise is forward, counter-clockwise is reverse. Easy. FWIW, the magnetic "key" is actually an ingeniously designed emergency cut-off switch. I tested it, works a treat and easy to pop back in (wait 3 seconds) and go again. As advertised, it's easy to cock up out of the water, and equally easy to just unclamp and store under the seat. No leaning over the stern required, you can do it all while sitting. So many bad memories of hanging off the sterns of various boats in a steep chop, trying to unstick a stuck outboard... no more!
When we set out, the wind was blowing about 8-10 knots with maybe a 1-foot chop coming across the lake. Turned the motor and use it to push away from the dock, went dead upwind at full throttle.... chugging along at 3-ish knots, no problem (remember, no mast, hardly any windage). Went to half-throttle upwind and it was quite evident that the boat was not moving over ground, although barely gurgling over the water. Turned crosswise to the wind, put the boat at half throttle and pushed along for 1/2 mile for testing. Had to cock the motor over a bit to avoid leeward drift... I was sighting over to some trees on shoreline, forgot to bring the compass!. Also forgot to drop the CB, hence the drift. No matter. At half throttle, sideways on to the wind, she went along at about a brisk walking speed (again judging by shoreline); at 1/4 throttle, she went at a slow walking speed judging by the eddies curling off the stern. Full throttle was running speed, again 3-ish knots with a small wake. I then went upwind again, same deal, full-throttle or we didn't move, as expected. We went back to the dock crosswind and then 1/2 throttle downwind. Was happy that full-reverse was effective, both for stopping the boat by the dock and for a bit of last-minute alignment of my stern up against the dock. I've sailed up to the dock many, many times, this was certainly more convenient and easier on the marital harmony!
All in all, the EP was exactly like paddling. At full throttle it was a knot or so faster than what two adults could do furiously paddling, except it does it for an hour straight with no work for me. At half throttle, it goes about as fast as I'd be able to get the boat to go while paddling hard, and 1/4 knot is "normal" paddling. Yes, sounds crazy to spend $1600 for a glorified paddle, but the advantage is that it doesn't get tired, I do. Absolutely fine for what I need - if there is wind it's just for dock maneuvering or moving thru places where I'd normally paddle - under bridges or thru the windless little straights separating the larger arms of our local lakes. I've done all that "the hard way," paddling anything from a Hobie Cat to a 20-foot sloop, and this is MUCH better. It's a lot of money, but I'm paying for the convenience and peace of mind - and the aforementioned marital harmony!
The "off-boarding" procedure was equally painless. I disconnected the battery and put it on the dock, then unclamped the motor and handed it to my wife. About a cup of water drained out from the propeller gear, it's water-lubricated. She handled the EP with no problem and carried it up to our car (didn't have to, but I appreciate it!). One thing to watch for is that the motor is, of course, top heavy - so hold it by the shaft about 2/3 down.
I'm curious to see what I can do with the EP in dead-calm conditions. We certainly get enough of that in the summer and it would be nice to hum along to some cove a mile away from the ramp and go swim. We shall see. What the EP WON'T do is push you along all day if you are out in a dead calm. In other words, it's useless for extended motor-assisted cruising, at least as set up. It's NOT an "iron jib." A 100W solar panel maybe changes things, but anything like that is well down the road for me, no worries.
Anyway, happy to answer any questions and next time I'm out I'll take some photos.
Cheers,
Cheers,
