Technicalities
So,
I began making measurements to figure out if my boat is class legal. There are two items I am concerned about and am looking for clarification.
First, on the mast datum band the rules state the top of the cuddy as the reference point for the top of band 1 "excluding any bead or collar around the partner opening". Does this refer to the molded lip that rolls up from the flat surface of the cuddy top, or does this refer to any sort of gasket or boot to close the hole?
Second, the spinnaker sheave is located so that the "top of the spinnaker sheave shall be no higher than 15 feet 5 inches above mast datum". OK, so what is the 'top' of the sheave. Is it the highest point of the roller itself (the cheek) or is it the saddle that the halyard rides in (a difference of 3/16 or 1/4 inch)?
The reason I am asking these very specific questions is it looks as if my mast does not meet these requirements (spinnaker sheave). I may have to shorten my mast by as much as 9/16ths of an inch. I want to be absolutely positive that my understanding and measurements are exact before I shorten the mast.
Please, no speculation on this. I'm looking for concrete information.
Thanks.
Thanks.
