Hi Folks,
Today (and for the past week) I find myself wondering about what the correct length is for the halyards - line, VS. cable. Both of my halyards will not fully raise the sails unless pulled through the cheek blocks (base of mast above cuddy) so that cable is riding on the sheeve. This just doesn't seem to make any sense to me since the braided loop at the end of the line which fastens the line part of the halyard to the cable is very difficult to pass through the block - and the cable riding in the sheeve seems like it could really put too much wear and strain on the plastic. So - shouldn't the cheek block only come in contact with the line portion of the halyard - or is this seemingly non-intuitive set up the way hings should be?
I'm also wondering about the woven loop on the halyard. When last I went out, I was hoisting the main when the woven loop came undone, separating from the cable. I tied a bolen through the cable loop, but due to the fact that the knot would not fit through the cheek block I was unable to sail with the main fully raised. I need to fix this before going out again and am wondering if the consensus is that you car re-braid the loop together, or if once it comes undone a new one needs to be considered.
