About ready to splash the boat and thought I had better check the CB. On the bottom of the hull there are two aluminum plates that hold a wedge in place. One of my wedges is loose, what is its purpose? Looks as if it might support the bushing above it but it doesn't reach it.
Also my down line for the CB has frayed through two of the three strands of rope where comes out of the CB trunk. Does that require CB removal to replace?
Lastly, with the boat on the trailer there is a rope coming out of leading edge of the CB and going up in the trunk. Looks as if it part of the down line but is a different color. Plus water appears to be seeping out of the rope's hole in the CB - normal? Was on mooring until a few weeks ago.
