DS1 Design Changes
Re: DS1 Design Changes
Postby Lifepilot » Sat May 30, 2020 12:10 am
Mine has wood thwarts and no outboard tank. Sail# 1111 1962.
Lifepilot
Postby tKhrist » Sun Jun 26, 2022 2:31 pm
I have added my Day Sailer to the spreadsheet.
Hull #: 9208
Class #: 1577
DOM: Late 1963-Early 1964
Cheers!
tKhrist
Postby GreenLake » Mon Jun 27, 2022 1:27 pm
Thanks and welcome to the forum!
Postby Dashaway » Tue Jun 24, 2025 3:47 pm
Now, I just got back into DSs ...
And I have not read all the interesting replies here (I will ... )
I was noticing -
Do they (DS I's) have a Thwart support (port and starboard) onto the CB Trunk ? (a question of evolution of the DSs I have seen both) (A Yes or No)
Are the formed FG seats colored, or (later) are they are white FG ? (again a "Yes" or "No")
And the early rudder changed it's design (see below)
I have a very, very old rudder, It's from DS 368 !!!
How can I send a pic. ? (I don't see a method here ?)
So you can see the orig. DS rudder - it's a work of wood art :!
Dashaway
Postby Dashaway » Wed Jul 02, 2025 6:49 pm
Now - I'll put this into the spreadsheet, if you tell me to ...
... but it's a problem of not having a Class #, and No Year - Dashaway
Evolution of this O’Day DS I -
To tell it’s age (year), and it’s Class #
(to be placed in order of the date of the changes, in the future)
Rub-Rail distance in stern (short vs longer) - Yes, It’s a short 8” distance !
Formed / Molded FG Side Seats - Yes ! (Light Blue Color)
Foam in the FG Side Seats - ?
Colored Seats (RD noted) Yes ! (Light Blue)
Matching the Light Blue Deck Color
Also matching the two Shelves color, and the Bulkhead color
Motor Well - No !
Wire Traveler - Yes (Wire is missing)
This had at least three evolutions on the DS Is
CB Trunk Shape - ? (Rounded on the back edge)
CB Trunk Main-Sheet Block - No (Believe it was added on later)
Ctr. Deck, Brass Bow Cleat (RD noted) Yes !
Floor Stringers - No
Mast Step (Screw Jack vs Tabernacle Step) - Screw Jack !
Two wood CB (thwart) supports, attached to the FG seats - Yes !
Early DS Is had this, then they did not, then it was added on later models
Rounded front edge of the Cabin (RD noticed some are “squared-off”)
But this may be when the production switches to the DS II, Etc.
Raised Bosses in the Fiberglass for the Jib Blocks, and the Halyard Cleats
Jib Cleats mounted onto the Wood Combing
_______________________________________________
Prev. DS Modifications:
Main Sheet Block & Cleat moved to Centerboard Trunk Location (previous to R)
Changes that are simply Repairs, and maybe some Upgrades:
SS Bow Plate (Orig. Brass Plate was Light Duty)
Bow Eye Moved Up (per. Previous Accident, and Re-Fiberglassing of the Stem)
Main Sheet to CB Trunk
SS Screws mounting Brass HW (Changed at some point ?)
Dashaway
Postby Cliff » Sat Oct 25, 2025 11:22 pm
Greenlake : I see the spread sheet: Just getting back into the forum. Wish to add my boat:
2 Questions:
1: Is col A meant to say "Sail No."?
2 What is col "Screen Name" referring to?
Cliff
Cliff
Postby GreenLake » Sun Oct 26, 2025 2:13 am
Cliff, welcome back.
"Screen name" for you would be "Cliff".
The first column is indeed the sail number.
I didn't make the spreadsheet, but I found it's easy to add your info. For some of the design features, you may want to read the discussion a bit to make sure you answer correctly.
Re: DS1 Design Changes, Manufacturer
Postby Cliff » Sun Nov 16, 2025 2:06 am
Interesting not 1 McGlaughlin is listed. Just noticed-they only made 16 boats.
Cliff
Cliff
