Reattaching side stay to mast
Postby gregL86 » Wed Jul 20, 2022 3:05 pm
I need to reattach my side stay to the mast. Luckily it snapped off when I was tightening the forestay on land vs sailing.
What’s the best attachments to use? It looks like a previous owner reattached the forestay with hex washer screws.
1973 DSII 6795
gregL86
Re: Reattaching side stay to mast
Postby GreenLake » Wed Jul 20, 2022 7:21 pm
Rivets.
The factory original is rivets where the mandrel stays in place. They are closed rivets and keeping the mandrel may make them incrementally stronger in shear (that's something I don't know for sure, but if you can find some with an aluminum mandrel, those would match what these boats shipped with (at least for the models I know).
Even standard aluminum pop rivets should be fine. Look up their shear strength: the stays are tightened to a few hundred pounds and you have three rivets sharing the load. But you should get the closed end ones, so water doesn't get in your mast during a capsize.
