Lil Maggie wrote:Continued...
Once the profile was cut out, there was (is) still more planing and sanding to taper off the trailing edge from the tip of the board aft, and on the leading edge as well. I plan to achieve a 3/8" radiused leading edge all the way down to the tip, then taper off the trailing edge to a squared off 1/8"...which is where I'm at presently.
Any thoughts? advice? do's don'ts?
p.s. GL I realize this topic might belong under repair and improvement...feel free to move it if so...
kokko wrote:Is there a reason you are starting from lumber rather than adding shape to the existing board?
jdoorly wrote:Hi Mike, I was contemplating doing a similar project this winter and was wondering where to find 'Dave Misunas's instructions'? Also, what do you figure is the widest the foil can be to not jam in the trunk?
