I am pasting from an additional post below. The problem is the receiver is loose and I don't know if a bushing inside (if there is one) the port side of the cb is missing. If you can recall from memory all of the details of the board and the hardware I might be able to restore it. The hole is damaged and I only know how it looks now
If you wist to email a direct repy my email is
rickral@cfl.rr.com
I will call if you want to give out a phone number. My brother who has a lot of experience with fiberglass is coming over tomorrow and a soonest reply would help.
The post continues.
The centerboard was sagging so I pulled it. The crank is slightly worn as is the metal bushing on the starboard side of the CB. The inside of the hole is augured out pretty badly. I plan to epoxy it into shape with JB weld so it will hold better.
The big issue is there is a bronze piece on the port side of the CB well that is loose with cracked fiberglass around it. I assume (dangerous thing to do) that it needs to be epoxied back in place. The damage was most likely caused by an overly thick gasket pulling the lever out to far which would not allow the pin to engage properly. This probably caused the auguring out of the CB hole.
I am wondering if my assumption that the piece on the port side belongs in the well and not on the CB.
If my assumptions are correct the question revolves then around the well. Is it single or double walled? Could I cut out the piece and reinstall it?
The boat is a 1985 Spindrift DS1
Any advice is appreciated.
Thank You
Rick Liebler
