Mooring a DS1
Mooring a DS1
Postby mfeldman » Tue Jul 05, 2011 9:48 am
I moor my DS1 for the entire summer and I was wondering whether it was better to attach the mooring line (pendant) to the bow cleat or to the bow ring?. Whichever one I use, I'll attach a backup line to the other, but I'm not sure which one is sturdier and should take the force of the boat pulling against the mooring.
Mike
mfeldman
Postby ctenidae » Tue Jul 05, 2011 11:05 am
I don't have a bow ring in mine, so I tie off to the foredeck cleat. In my case, I'm sure it's quite secure, as it's a attached to a 2x6 length of red oak that's firmly attached to the underside of the deck and glassed to the hull at the bow end and to the stringer that the panel leading into the under deck space attaches to at the aft end. The whole foredeck would need to rip off for that to come loose, in which case, it's unlikely anything else would have held it, either.
Formerly 28 cents
DS1 1114
ctenidae
Postby K.C. Walker » Tue Jul 05, 2011 3:14 pm
Mike,
I think either one would be fine as long as you set up your mooring properly so that you minimize shock load. I think if you hook to either one and then back it up with the other it's definitely belt and suspenders. You should be fine.
Postby Bob Damon » Wed Jul 06, 2011 7:49 am
As part of your annual maintenance, I would check to make sure the nut(s) on the bow eye are tightened. Over time they loosen up with the vibration. I replaced mine with self locking nuts. The bow eye should be fine for mooring.
Bob Damon
Class Measurer
Postby Baysailer » Wed Jul 06, 2011 8:22 am
Sort of on topic here's a mooring horror story I came across last week. Actually its an impressive story if you read to the end.
http://www.pearsonariel.org/discussion/ ... Ensign-796
I attach the mooring line to the bow cleat and use the bow eye as a backup. I do check the bow eye nut like Bob recommends.
Baysailer
Postby GreenLake » Wed Jul 06, 2011 8:47 pm
I've had a bow eye break on me (the bolt broke clean through). With the trailer at the launch and the boat in the water...
Postby Alan » Wed Jul 06, 2011 10:10 pm
I haven't had a failure of either a bow cleat or bow eye, but on a related topic:
I had a winch rope, standard hardware store nylon stuff, snap near the clip that attaches to the bow eye during a launch. The immediate fix was to tie the broken rope to the clip, and later I replaced the winch with an old one, with steel cable, inherited from my father-in-law.
Then I started thinking about what a snapped steel cable might do, so I bought a 20-foot seatbelt-type strap to replace the rope in the old winch. Cheap peace of mind for the over-imaginative...
Postby GreenLake » Thu Jul 07, 2011 1:08 am
My wire has long been replaced by 3/16" (or 1/4" ?) Amsteel. I spliced a metal eye into it for the snap shackle to the bow eye. Amsteel is really easy to splic, being a single braid. It has worked well for me. Should be strong enough to lift boat and trailer vertically... but very light, hopefully reducing injury if it ever fails.
Belt type material is a great way to go as well, if you can get it.
Nothing helps, of course, if the bow eye gives when under full load...
In my case, the failure could have been precipitated by someone banging the bow eye from the side (docking?) with a stress crack and finally corrosion failure. Luckily, when it went, it was at low tension.
Postby TIM WEBB » Thu Jul 07, 2011 11:48 am
If anyone wants to buy the seat belt webbing, you can get it here:
http://www.paragear.com/templates/parac ... parent=193
It's the Type 24. You can buy it by the yard or roll ...
- Tim
Postby Alan » Fri Jul 08, 2011 4:33 pm
Thanks, Tim. I found a ready-made strap here:
http://www.cabelas.com/product/Boating/ ... t104632380
but I've been wondering if 20 feet is long enough, so a source of extra webbing material is helpful.
Postby GreenLake » Fri Jul 08, 2011 5:20 pm
The maximal distance I've ever had to cover is from the winch to the rearmost roller. On my trailer, that distance is definitely less than the length of the boat. So, for that configuration, 20' would probably do.
