As I refinish my deck, I'd like to put something around the mast at the cuddy roof to protect the gelcoat from the mast, as well as seal the gap from water seepage. I don't see any particular part in the available parts lists with this function.
To those of you with keel-stepped masts, do you use a mast boot, and if so, what is it made of and how is it secured? Is this something attached to the mast or through the hole as a sleave?
