Carlos,
Good Luck. Let me know how it works. Just a cautionary note: The centerboard is like a lever. In the original setup, the fulcrum is the bottom of the hull, and the force on the fulcrum is proportional to the ratio of the length of the board below the fulcrum to the length above the fulcrum - all else being equal. if you move the fulcrum up (i.e. if the board is no longer hitting the bottom of the hull, and is rather resting against your shim, the force on the fulcrum is much increased, and this might not be good. Your board may or may not still wobble enough (or bend enough) to hit the bottom of the hull which would eliminate the problem. My shims still let the board hit the bottom of the hull, so no problem, but it still wobbles, and I don't like it. What it doesn't do anymore is to move so far to port that the brass center plate with the square hole comes off the square portion of the handle shaft.
Shims plus a narrowing of the slot at the bottom should actually reduce the wobble, and allow the shims to be tighter without becoming the fulcrum. But note the minimum standard for the width of the slot in the racing rules. My shims were a temporary fix 'till I could work out the geometry and so I could get the boat in the water and not worry. My previous post was way too long already, so I didn't share this extra detail. It may all be BS anyway, but it makes sense to me.
Dan
