by Bob Hunkins » Wed Jul 02, 2008 2:51 pm
It's probably ok, the most likely problem seems to me to be from bimetallic corrosion - Two dissimilar metals in constant contact with each other in a wet environment, especially a salt water environment, will slowly react, and one will corrode faster than more than it would normally. You see this most around stainless steel rivets put into aluminum masts. To stop that corrosion, you can keep the copper in its insulator, i.e. don't strip the wire.
If you have an old stainless steel shroud, you can use some of the strands from that to secure the shroud to the spreader. If it's nice and snug, i.e. you can't pull the shroud away from the spreader by hand it's probably good.
Regardless of the type of wire you use, make sure it's covered up with some sort of tape, electrical or rigger's tape to keep any sharp ends from catching on a sail and possibly tearing it.
Bob Hunkins
#11750, "Surprise"
San Leon, Texas
