jdoorly wrote:triathjohn your pics would indicate you have aquired quite the racing boat.
GreenLake wrote:Pictures are always good.
On none of the boats I've sailed was the connection between boom and mast secured solely with tension from the sail. My expectation would be that a good set of pictures would allow us to help you identify what precisely went missing in your setup.
triathjohn wrote:GreenLake wrote:Pictures are always good.
GreenLake Can you tell me how to post pictures in a conversation. I posted some in the photo section but I would get more results if readers didn't have to go to the photo section to try to find my pictures.
Thanks.
Lil Maggie wrote:Right so you see no set-screw or anything of the like that would keep that peg fixed to the boom end casting, correct?
I have the regular Dwyer gooseneck on my DS 1 (btw, you have a thoroughbred of a boat), so one of the race-heads might be better at helping you out, but it would seem to me that once that peg is in the boom casting it shouldn't come out, not easily anyway, and to remove your boom you should do it via the vertical clevis pin/round cotter that holds the actual gooseneck (the U-joint & peg) to the hinge. I'd try wrapping enough teflon tape to that peg and ram it in the hole as far as it goes, or like I said earlier bond it with liquid metal (epoxy), a pretty drastic and butcher-like thing to do but effective
triathjohn wrote:
If I epoxy them together then I can never take the boom off.
look at your picture carefully
[thumb=1421]
right above the square peg there is a riveted or fixed pin (vertical movement) hinge; between it and the part that's riveted to the mast there is another hinge (lateral movement), this one, instead of a riveted pin has a clevis pin with a ring-type cotter pin on the bottom end; remove that cotter pin and push the clevis pin upward to remove it...that is the way your boom should separate from your mast (provided the "square peg" remains attached to the boom end casting)[/u]
