hi, i posted in the wtb category that I was looking for a used protor mast to update the original mast on my ds1 (sail no. 162) wife won't let me spend the money for a new mast (1500 or so), but the old stock mast is tired, with internal old halyard blocks, unflexible etc, and she (not the wife) sure has trouble keeping up with the other boats,
then capt seasick thought i should try some other things first --" I think that I would begin with a PERFECTLY smooth and fair bottom, Next, I would try to get the correct shape on the foils (rudder & centerboard) Next, I would make certain that the hull is the correct weight, and has not picked up water. Next I would make certain that the rig tune is correct to give proper helm, pointing and power for the conditions. If that failed to get you to the front of the fleet, I would buy new sails, and repeat the process again, before buying a new mast. I think changing the spar will yield the LEAST gains of any change you make on the boat.
That is my opinion, I hope it is helpful"
then i said --
thanks for your thoughts mike....just to let you know -- the bottom is as near perfect as it can get, foils seem to be original to the boat, sails have been used for 3 yrs -- probably 15 to 20 times a year ( i think that makes them middle aged), tuning is harder because donut on base of mast is stripped -- it does not go down anymore -- shrouds are at their limit, oh and mast was broken and repaired before I got the boat)....so thats why i think a newer/lighter mast would help and then it would give me better opportunity to tune the rig. (and also make it easier to travel because it would be lighter to place and re-place) .
if anyone has another thought..pls let me know..thanks
