Hey all:
Went out today for flight #4 on my boat. Solo.
I arrived at the ramp only to find the weather a bit stronger than I'd like for my first attempt at singlehanding: Wind 15-20, gusts up to 25, and very gusty: whitecaps here and there, leaden clouds after yesterday's record-setting rain. Knowing it was SUPPOSED to calm down a bit, I sat for about 30 minutes. The whitecaps abated, the air became steady and consistent, not so gusty, and the trees stopped showing the undersides of the leaves. Okay, I thought, now or never. I rigged things up which took about 35 minutes - not bad, including reefing the main. The wind conditions held steady.
Got out of the no-wake zone and hoisted things up. I knew the main looked different because of being reefed, but it took me several minutes to realize that - again, like last time - I forgot to put in the battens. Sheesh. Once I got the feel of the wind strength and direction, I think I did pretty well handling things. Sure wish I had installed the jib sheet camcleats I bought, instead of leaning far forward to use the old jam cleat on the fore end of the centerboard trunk. THat's my next project. It will help going solo.
Tootled around for about an hour, then the weather suddenly got a LOT brisker, and whitecaps started dancing up around me. It was then that I realized that, although I hadn't gone very far from the ramp, I was directly upwind of where I wanted to be, and I had to wing and wing it to get back. I even managed to get in a jibe, which was fun. Once within spitting distance, I cheated and turned on the engine. THings were blowing pretty hard.
I'm very glad I put in the reefing system, and used it, and I'm still undecided on using the tiller extension I bought last week. It feels counterintuitive , and is harder to push around than just the tiller. BUt I suppose it's a matter of acclimation.
Upon getting back in and taking things down, I was just at the point of strapping the front part of the mast to the mast support on the trailer - just about ready to drive off - when I heard a little metallic "ping" come from the front end. I looked and saw the forstay clevis pin lying on the deck, and the forestay fork had popped off. The retaining ring was nowhere to be found. It was not there. This means that I conceivably had been sailing in this wild weather with NO RETAINING RING IN MY FORESTAY TOP FORK CLEVIS PIN HOLDING IT TO THE TANG. So I learned a huge lesson - to double check each and every thing on the boat before I go out. All it would have taken is a quick visual check on the shrouds and stay. (That's the warning!)
But it was a wild ride, really. Especially on my way back when I went from directly with the wind to a broad reach, and started zooming along. The wake behind me looked like a motorboat.
I also gained a lot of confidence in my ability to go out alone (one reason I bought this boat) and my ability to assess the weather. I really did sit and wait until it felt manageable.
Carlos
