Before progressing (or not) I wanted to get the advice
of anyone who has tried this, or knows of good reasons
not to...
I have a 17’ daysailer, very much in the form style of
an O'day Daysailer.
both the transom and back decking areas are soft, and
all of the wood on the transom is rotted/rotting and
delamnating. My big winter project is to repair this
damage.
My initial plan was to remove all damaged wood and try
and fit some 5/8" marine ply in and glue it in place,
but I think this won't have the flexibility to conform
to the hull shape. My secondary plan was to epoxy
successive layers of luan to the inside of the
remaining fiberglass skin when all rot is removed.
This seems to be the style of the original (now
rotting) construction.
I'm most of the way through removing the hardware from
these areas, and realized that I could simply cut out
the transom and work from that perspective.
As I see it this would:
1. Give me better access to the back deck area to glue
in supports and wood.
2. Allow me to trace the transom on a sheet of 5/8"
plywood, preinstall all of the hardware without having
to mess about in the cramped enclosed back of the
boat, and then reinstall the transom with glass/tape,
epoxy, and more than a few Hail Marys.
The downside being that reattachment promises to be a
serious pain in the butt, and may not exactly match
the current sheer (which now that I think of it is
remarkably flat actually).
Any thoughts?
Thanks.
-Glenn
