I just purchased a DSI Hull# 13742, Sail# 2383 from a widow and she did not know much about the boat
[thumb=400] and [thumb=399]
I had a DSII 20 years ago but this DSI has some differences I don't completely understand. There is an adjustable wire that runs from one side of the inner hull through a fixture on the keel to the other side. It is there to reinforce and take load from the mast stays.
[thumb=401] [thumb=402] [thumb=403] [thumb=404]
My question. Is this typical of DSI's and if so can someone explain its full function and the appropriate tension it should have. Also the bronze fitting on the keel has an adjustable ring. What is it its purpose. To adjust the height of the mast?
