My DS1 (#818) originally came with a wire horse traveler that has the mounting points molded into the corners of the aft deck. A previous owner scrapped the wire horse and used the spinnaker blocks mounted aft to make a control line triangle for the boom.
From what I have read on this site it isn’t the most desirable set up for racing as most racers have gone for a traveler system with more control that allows shaping the triangle for improved main sail control.
I am more of a cruiser than racer but have considered restoring the wire horse system and freeing up the spinnaker blocks in order to use them as intended. Plus I like the idea of using a system original to the boat.
I was wondering how common was the wire horse system ? Appears to only be on early DS1s.
Anyone here still using the wire horse traveler ? What do you think about it?
