Reef point location
Reef point location
Postby John Stevens » Fri May 16, 2008 12:49 pm
The DS1 I bought doens't have reef points in the main.
I'm going to use the boat for "daysailing" with my wife and in the future some racing but probably with new sails. The main seems large, should I go with a regular reef point under the first batten or a deep reef above?
TIA,
John Stevens
Postby calden » Fri May 16, 2008 1:32 pm
John :
I've got one set of reef points, and used them maybe four times. I can't imagine being out in winds that would require a second reef! If it were that bad I'd come in to shore on this small boat. I would think that one reef would be all you'd want, especially for recreational sailing with family.
Carlos
DS I #1653
calden
Postby John Stevens » Fri May 16, 2008 2:02 pm
Carlos,
I agree, I would just go with one, just trying to figure out were to put it?
Regular reef or deep reef?
John Stevens
Postby calden » Fri May 16, 2008 4:31 pm
Oh, right, you did say that, didn't you...
I think a regular, not deep reef would be fine. My opinion from three years of sailing.
Carlos
DS I #1653
calden
I would agree, one regular reef
Postby Roger » Fri May 16, 2008 7:23 pm
If I recall correctly the luff reef crinkle is 39" up, and the leech is 41" up, but either way it is just below the first batten.
This boat sails really well in a blow with just one reef. I was amazed.
Postby John Stevens » Fri May 16, 2008 7:51 pm
Thanks guys, good to hear.
John Stevens
Postby kokko » Mon May 19, 2008 2:08 pm
Thanks for the timely topic. My sails may be the original and are in ok shape, but lack a reef. I found the rolling reef cumbersome since I had to disconnect the mid boom block and do not have the "claw". I got a quote of $175 to put in a reef from my local sail loft, but I can't justify the cost for 40 year old sails. I plan to use my little grommet kit and put them in myself. It won't be perfect, but it will work.
Postby John Stevens » Mon May 19, 2008 7:33 pm
175 is a lot. The sailmaker here in Central Florida is charging 75.00
John Stevens
Postby calden » Mon May 19, 2008 8:51 pm
You can get a do-it-yourself reefing kit at Sailrite. Includes the patches and grommets for the sail, bullet block and cleats for the boom and mast, and all line. $51.
I did it, and it's fine.
http://www.sailrite.com/jiffy-reefing-kit
Carlos
DS I #1653
calden
