Description:
Seafoam green deck, white hull, black boot stripe. No ID number except for a stamped serial number just under the hull to deck joint on the starboard bow. IT was a number in the low 10,000's, but I don't recall it exactly. Probably has maroon scuff marks on the hull from the contact it had with the car.
The inside was reinforced with klegecell and fiberglass, which was still unpainted. The thwarts and combings were removed.
Some brownish colored fairing compound was on the exterior hull.
The forward seat tank had an inspection port installed.
If someone happens to find this boat washed up along the Gulf Coast (or the anywhere), somehow, someday, and she's relatively intact, I would like to have her back. I've searched the local area and even looked through some post storm aerial photos to see of any likely shapes, but no luck. Of course it's an extreme longshot. I doubt I'll see her again, but it's worth noting the loss.
