Spreader Set-up
Spreader Set-up
Postby ssawyer » Tue May 19, 2009 2:10 pm
My new (to me) 1985 Spindrift Day Sailer has spreader brackets which are pop-riveted to the mast. They appear a little loose. Is this the normal way the spreader brackets are attached? Is there a common retro-fit which owners recommend to take the looseness out?
Scott
PNW
ssawyer
Spreaders
Postby kokko » Tue May 19, 2009 3:04 pm
I have a '68 DS1 and had the same problem. I drilled out the old rivet and secured it with a new aluminum pop-rivet. I think it was a 3/16"
Postby seandwyer » Tue May 19, 2009 4:13 pm
Same here. Aluminum rivets broken - need to be drilled out and replaced. Going with aluminum so as to get around the problems of different metals not getting along. Silly metal.
Sean
DS1 - 3203
seandwyer
