PHRF Rating Questions
Postby jdubes » Fri Jun 19, 2009 8:58 am
I'm trying to answer a few questions on this PHRF rating sheet for my boat.
Can anyone help answering these questions.
1. Keel Ballast Weight?
2. I=Foretriangle Height?
3. J=Foretriangle Base?
4. P=Main Luff E=Main Foot?
5. ISP=Spinnaker Halyard Height?
Thanks Jason
jdubes
Postby Bob Hunkins » Fri Jun 19, 2009 10:41 pm
PHRF is intended for keelboats. Smaller boats like the Day Sailer use the Portsmorth handicap. You can find a PHRF conversion in the Portsmouth Yardstick on the US Sailing Web Site.
If you really need those numbers:
1. Keel Ballast Weight? The Day Sailer doesn't have keel ballast. The centerboard weight is max 25lbs.
2. I=Foretriangle Height? - measure from the partners to the forestay hounds.
3. J=Foretriangle Base? - measure from the stem fitting on the bow to the partners.
4. P=Main Luff (see class handbook on this site) distance from band #1 gooseneck to band #2 on the mast.
E=Main Foot? - see class handbook. (gooseneck to black band on the boom.)
5. ISP=Spinnaker Halyard Height?- measure from partner to spinnaker halyard block.
Bob Hunkins
#11750, "Surprise"
San Leon, Texas
Bob Hunkins
Site Admin
Postby jpclowes » Sun Jun 21, 2009 8:00 pm
Your PHRF should be around 262. It will vary a little depending on where you are.
J .P. Clowes
DSI 14083
jpclowes
Postby Bob Hunkins » Fri Jun 26, 2009 10:25 pm
The US Sailing table to convert Portsmouth D-PN to PHRF is here:
http://www.ussailing.org/portsmouth/table_v.asp
The Day Sailer's DPN is 98.5 = 261 PHRF.
Hope that helps.
Bob Hunkins
#11750, "Surprise"
San Leon, Texas
Bob Hunkins
Site Admin
