How much "play" should there be in the centerboard when it is lowered?
This afternoon we were out and were becalmed in some relatvely choppy water. We were only rolling maybe 10-15 degree but the centerboard was banging back and forth in time, pretty loudly. I thought there was something wrong and lifted it up and then we motored in (no wind anyway.)
I put the boat up on a boat lift and went underneath, and could move the CB almost an inch back and forth. I pulled the center pin to see if anything was really loose (and picked up the CB from the bottom of the lake.)
The pin is fairly tight through the centerboard (no signficant rounding of the corners), and the end of the pin seems to sit fairly tight in the indent on the other side. When we were out, the screws were tight, as I had earlier had issues with the CB raising.
The rubber gasket feels almost new, neither frayed nor rigid. Any advice or feedback would be greatly appreciated. My "first mate" is beginning to question the sea worthyness of our new old daysailor.
Also, any tips on aligning the CB when I reinstall it would be appreciated.
And finally, am I correct in believing that there are no washers or other spacers that go outside of the CB but in the CB tunnel?
Rick
