Well I decided to take care of a crack on the floor near the seat of my newly purchased Spindrift DS1. I ground down the top layer only to find a wet cardboard material.
I assume that is balsa wood.
Under that material I did a tap test and all sounds good. I ground some floor test spots several inches from the crack. The balsa material was very wet.
Any advice on what to do about this situation? Can I let balsa dry and just put a few layers of glass on the ground areas and call it a day.
