gooseneck
gooseneck
Postby mcqmga » Thu Jul 10, 2014 9:26 am
Guys, - Started rigging DS1 today ( for first time) - I have mast up and started to attach boom - the piece that slides in the goove of the mast(gooseneck?) and attaches to boom appears to require a "pin" which is missing from the PO. Is that correct?
Bob
mcqmga
Re: gooseneck
Postby TIM WEBB » Thu Jul 10, 2014 9:51 am
Bob, are you referring to the tack pin? That is normally a "captive pin" that is part of the gooseneck casting:
http://www.drmarine.com/proddetail.asp?prod=DR116A
If yours is missing, any old pin would do, as long as it fits the hole and is long enough? The captive one has a small roll pin in the end to hold it in place, and the hole in one "fork" of the casting is slotted to allow the pin to be inserted through the main tack cringle, but not fall out the other side. Make any sense?
Re: gooseneck
Postby mcqmga » Thu Jul 10, 2014 10:10 am
Tim - Home » General Sailboat Parts & Gear » Mast, Boom & Accessories
Gooseneck Slide Only.
This is the piece that the boom attaches to-right? Should there be a "pin" or is there other "dual" purpose rigging for this function ? The piece you speak of and picture is all there.
(Sorry , not as computer savy as you - pic did not come through only description)
Thanks - Bob
mcqmga
Re: gooseneck
Postby TIM WEBB » Thu Jul 10, 2014 10:27 am
Just cut 'n' paste the link directly into the message, and it should appear as a "clicky".
Your gooseneck slide should be attached to the boom with a "U-joint", held together with clevis pins, as shown here:
The spring thing is part of the roller reefing system (highly ineffective BTW).
Can you post a pic of what you *do* have?
Re: gooseneck
Postby mcqmga » Thu Jul 10, 2014 12:35 pm
Tim - I'm not at boat now, so can't take pics - - But looks like "clevis pin" is missing - I found one with PO items but was too short ( no room for cotter pin ) - I'll head down to local marine supply for replacement - It appears from your pic is requires "close fit" - no play ?
Thanks for your feedback -
Bob
mcqmga
Re: gooseneck
Postby jeadstx » Thu Jul 10, 2014 12:48 pm
This is what the end of the boom should look like with gooseneck attached (boom shown upside down).
Boom End at Gooseneck.JPG (64.3 KiB) Viewed 13573 times
Re: gooseneck
Postby mcqmga » Thu Jul 10, 2014 12:56 pm
oK - THANKS John/ Tim -
Bob
mcqmga
Re: gooseneck
Postby TIM WEBB » Thu Jul 10, 2014 9:37 pm
mcqmga wrote:Tim - I'm not at boat now, so can't take pics - - But looks like "clevis pin" is missing - I found one with PO items but was too short ( no room for cotter pin ) - I'll head down to local marine supply for replacement - It appears from your pic is requires "close fit" - no play ?
Bob
OK, no worries. Perfect pic to illustrate John! Yes, the clevis pins need to be "just the right length". If your local place doesn't have them, you can get them from D&R. On TRW, after I added the boom vang, the open, "middle" part of the U-joint started to collapse/distort, so I made a solid SS one. Also, I note in the D&R pic (which is also upside-down) that they are using cotter pins on the clevis pins. I've been using circlips all along, and they get quite distorted in that application, so I'm gonna change to cotters as well ...
Re: gooseneck
Postby jeadstx » Fri Jul 11, 2014 1:17 pm
The boom on the Rhodes 19 and the Mariner is the same as used on the Day Sailer. Stuart Marine (current maker of R19 & Mariner) sells the individual parts of the gooseneck including the correct length clevis pin. http://www.stuartmarine.com/spars-rigging-1972-1980/ The gooseneck parts are at the bottom of the page. Stuart's prices are higher than D&R for the complete gooseneck, but they do sell the individual parts.
