by 1987DSPrecision » Tue May 02, 2017 9:33 pm
Question on a Precision DS 1:
There are 2 transom drain plugs.
1 drains the cockpit.
1 drains space between the sandwiched hulls.
Is there any reason for the cockpit drain to connect to the other drain hole?
I working on repairs and am thinking about sealing off the cockpit drain plug so that water in the cockpit never enters the space between the hulls.
Does that make any sense?
1987DSPrecision
by GreenLake » Tue Jun 27, 2017 2:29 am
I keep thinking this question must have been asked before. Have you had any luck reading the older posts?
