Rudder Dimensions
Rudder Dimensions
Postby OldandBusted » Wed Aug 10, 2011 11:58 am
Can anyone tell me the dimesions for the rudder for a ds1? I'm thinking of making one out of plywood to avoid paying $550 for a new one.
OldandBusted
Postby GreenLake » Mon Aug 15, 2011 6:48 pm
You'll find the class specifications and measurements on this site, in the menus at the top. Here's the link to the file you need:
http://daysailer.org/pdf/dsbylaw3.pdf
If you make your own, give it a nice profile, so it will work better.
I just went through the exercise, and here are some drawings:
938
937
936
I strongly recommend that you encase the plywood in a good layer of glass cloth (using epoxy). That should make the skin tough enough to withstand the inevitable abuse.
Rudder Dimensions
Postby OldandBusted » Tue Aug 16, 2011 8:46 am
Wow. That's thorough. Thank you very much for the dimensions and advice.
OldandBusted
Postby GreenLake » Thu Aug 18, 2011 11:56 am
The process of building a new rudder is reasonably quick. I found that waiting for full cure of the top-coat took the longest, followed by fairing the blade and waiting for the fairing compound to cure (repeatedly). Roughing out and glassing the blank was fast by comparison.
So, if you're worried about the sailing season slipping away, I'd stop after epoxying and glassing the blade and sail with it, postponing the fairing and finishing. Will get you out on the water, but won't give you the full benefit of a faired and polished blade.
Postby GreenLake » Thu Aug 18, 2011 12:01 pm
For more details on my rudder project see this Building a Rudder thread.
Users browsing this forum: Google [Bot] and 14 guests
