Replacing Chainplates
Re: Replacing Chainplates
Postby GreenLake » Sat Jun 28, 2014 3:21 pm
Tim,
From what I've read (and dimly remember), lock washers would probably be inferior here.
Looks like there's room to drill the bolt below the nylocs. If yes, you could simply drill and push some SS wire through and twist off. For peace of mind. Like, for use on the FL120 or wherever you really don't want them to come loose :)
Postby TIM WEBB » Sat Jun 28, 2014 11:21 pm
Yeah, you're probably right GL, although I doubt lock washers would work any better on the half-rounds either. I like your safety wire idea, tho don't know how accurately I could drill such a hole thru the bolts? I was actually thinking of using those last few threads to just screw on 4 more nyloc nuts as "lock nuts" ... ?
Trust me: I really don't want them to come loose, whether it be the FL 120 or an afternoon sail on Lake Dias! ;-P
Postby GreenLake » Sun Jun 29, 2014 2:43 pm
I don't know whether unusual accuracy would be required. A bit of patience perhaps, and a cobalt bit, because the bolts are stainless. You can always to a trial run on another bolt.
Postby jeadstx » Sun Jun 29, 2014 5:02 pm
If when drilling you use a small amount of oil, the drilling will be easier.
Postby TIM WEBB » Sun Jun 29, 2014 8:54 pm
GreenLake wrote:I don't know whether unusual accuracy would be required. A bit of patience perhaps, and a cobalt bit, because the bolts are stainless. You can always to a trial run on another bolt.
jeadstx wrote:If when drilling you use a small amount of oil, the drilling will be easier.
We do a lot of drilling of SS at work, and yes, we use both cobalt bits and fluid. However, I was not able to do the drilling I needed to do there ...
Postby GreenLake » Sun Jun 29, 2014 10:06 pm
We were thinking that you'd do this one calm afternoon on the lake - with a cordless drill while hanging over the side :)
Postby TIM WEBB » Sun Jun 29, 2014 10:17 pm
Nah - with my luck, I'd drop the <beep> thing overboard! ;-P
Postby jeadstx » Mon Jun 30, 2014 12:27 am
Greenlake, I thought he would try it while sailing with his daughter at the helm.
Postby TIM WEBB » Mon Jun 30, 2014 3:54 pm
*NOW* you're on to something John! ;-P
Postby GreenLake » Tue Jul 01, 2014 2:44 am
Yes, John. And with his wife getting it all on video. We can't wait. :D :D
Postby TIM WEBB » Tue Jul 01, 2014 9:19 pm
Yeah, that would be sure to land on someone's "Ultimate Fail" compilation! ;-P
Postby jeadstx » Wed Jul 02, 2014 12:43 pm
Or successful insane sailing.
Postby GreenLake » Wed Jul 02, 2014 12:57 pm
Somewhere is the picture of some guy's girlfriend doing yoga (and headstands) on the foredeck of a DS. Hard to compete, but if you give it a good try?
