Centerboard Wood
Centerboard Wood
Postby trial1 » Thu Feb 09, 2006 4:57 pm
Hey all -
I have recently acquired an old DS I (approximately '59 vintage) and all the encompassing repair fun. My new treasure was deprived of a centerboard and I am now beginning the creation process. I have done a fair amount of research thus far, but have failed in finding definitive information regarding the type of wood to use for the centerboard core.
Right now I am leaning towards Redwood because I can get it rather easily and cheap.
I have also though of using a Cedar but I am not sure as to which type of Cedar would be best.
Spruce crossed my mind as another possible solution but I have only been able find construction grade thus far.
Any thoughts or recommendations?
Thanks.
trial1
Postby Peter McMinn » Thu Feb 09, 2006 5:12 pm
Spruce, I think, is the wood of choice.
Peter McMinn
Centerboard
Postby swiftsail » Thu Feb 09, 2006 6:59 pm
I built my last one out of western red ceder. I cameout really nice but in hindsight I would have put strip of harder wood on the leading edge.
Steve
DS 307 "Security Risk"
DS 14024 "Flight Risk"
Live Slow, Sail Fast
swiftsail
Postby trial1 » Mon Feb 13, 2006 10:17 am
A harder wood for the leading edge - good idea. I will incorporate that.
Has your board taken serious abuse?
trial1
Centerboard
Postby swiftsail » Mon Feb 13, 2006 3:24 pm
The abuse comes from over rotating the board forward into the front edge of the trunk.
Steve
swiftsail
Centerboard Wood and Shape
Postby Gus » Tue Feb 14, 2006 7:21 am
Check out this site.
http://www.philsfoils.com/Designs/DS.html
Gus
DS 11100
Sailing and racing Day Sailers since 1977
Gus
Postby Bob Hunkins » Tue Feb 14, 2006 11:14 am
Dave Misunas wrote a great article on the subject, in case you haven't read it. I have a copy available here:
http://www.bobhunkins.com/mt-archives/000020.html
I used spruce in my boards, mostly because my boat is heavy. If your boat is light, a heavier wood would be better, so long as you don't exceed the 25 lb limit.
The spruce I found was mast grade, quarter sawn, with very tight rings so I didn't need to do the trick of ripping the piece and alternating the grain sections.
Bob Hunkins
#11750, "Surprise"
San Leon, Texas
Bob Hunkins
Site Admin
Postby trial1 » Tue Feb 14, 2006 12:10 pm
Gus - I have checked out phil's foils a few times now but would rather craft the centerboard myself (mostly because I enjoy the challenge). Thanks for the link anyways.
Bob - The Dave M. article posted on your website was the catalysts for me finally deciding I could/would build one myself. The PDF's on your site have been extremely helpful. Thanks for those.
Unfortunately, I have no idea how much my boat weighs since I have only just started working on it. I was going to use an ash or maple for the leading edge based upon swiftsail's recommendation and a softer wood for the the rest of the board to save money/weight. In the end, I wasn't able to find decent spruce in my area and decided to make the whole thing out of ash (found a good price on ash). I am going to be really close on the weight limit of 25lbs. - I plan to replace a section of the ash with foam prior to fiberglassing if I don't make it.
trial1
