I have seen pictures of Daysailers with the forward foot or so of the cockpit combings cut down so that they don't leave such a crease in the crew's rear end while hiking out. I am considering this modification on my DS1 and have two questions. First, can anyone advise as to the optimum distance aft from the cuddy cabin to cut down the combing? Humorous comments re: how wide the is crew's rear end will be appreciated though not the most helpful. Second, have those who have made this modification found that they take more water in over the side? I do not race but sail in the ocean in winter conditions where hiking is key to staying upright. I would like to know before I start cutting, however, whether full width combings help to keep the boat dry or provide any additional margin of safety when hit by a gust. Thanks in advance for any advice you can supply on these points and any other suggestions for this modification.
Evans Wohlforth (nyew-at-gateway.net)
