I'm going to break this down into parts, all pertaining to the hull stringer repair, whats wrong, filler (wood or closed cell foam), maintaining correct hull shape.
Whats wrong... The hull has damage, the previous-previous owner did a very poor repair job and it has failed. Add to that, there are two cracks in the hull. I noticed when I first purchased her that one stringer had damage and suspected it to be damp. Turns out the entire piece is rotted, it looks like both sides are rotted beyond repair causing the hull to be soft. I've decided, since the rest of the boat is being repaired/restored to new that this has to be done.
Hull Damage, first a wide shot and port and starboard cracks respectively.
Using a Dremel and their new metal cutting wheels (they hardly wear even after cutting stainless) I removed the top part of the stringer.
I wasn't prepared for what I saw after I removed the rot had turned the wood into pretty much soggy cardboard, and it was all still soaked, even after sitting indoors for over a month with excellent ventilation.
The length is ~110", measuring the "driest" piece I get 2" wide and 3/8" thick. What I don't know is does the type of hardwood matter? What type of wood was used, I can't tell by looking at the pieces in front of me? There is a post here http://forum.daysailer.org/forum/viewtopic.php?t=543 that mentions foam core being used, I suspect the wood was initially used as a filler/gapper so the fiberglass could be laid on top of it.
Has anyone replaced re-glassed them? (I'm not a noob at fiberglass work)
Finally,
The boat is sitting on the trailer but I suspect this isn't the best way to support the hull and keep it in her correct shape. Has anyone built a cradle or other type of sling? I was going to try and build a 4x4 sling and support her using four 2" straps one at the bow, transom, and fore and aft of the centerboard trunk.
Marc
If you skipped most of the post, what type of wood (or closed cell foam) to use, and what is the best way to support the hull during this process.
pheww.....
