Main Sheet block
Main Sheet block
Postby Glenn » Mon Mar 31, 2008 5:57 pm
Just finished some repairs to the mast on my new to me DS 3 and raised the mast in the driveway. As I tightened the mainsheet I noticed something wrong with the block. The sheeves in the mainsheet block are broken. It is a Garhauer part. Doe anyone know if I can get this repaired? D&R has a replacement but it is not the same as I have. The cam cleat releases from the bottom instead of the top. I think that would be awkward to use. Also has anyone ever removed the mainsheet block. What is behind it? Will I need to remove the center board to reach the backside to install the replacement?
Glenn
The mainsheet block screws in from the top
Postby Roger » Tue Apr 01, 2008 12:22 am
I have an extra one here if you are interested. Nothing wrong with it. When I added a traveller it had its own mainsheet block.
E-mail me at roger02 att mts dott net if you are interested and I can send you a picture.
