Hello, fellow DS sailors! New DS1 owner here with a puzzling trailer problem. I picked up a well-preserved 1969 or 1970 boat this weekend from an owner in rural PA that rides a Tee Nee trailer rated for 1250 lbs. The PO only trailered it on short local roads at speeds under 40 mph. He had installed two new tires on the trailer and greased the bearings. On my ride home, the trailer developed a bad shimmy at speeds over 55 mph - so much so that I drove about 50mph all the way home. The trailer has bunks that I consider too short for the boat, so I'll be beefing them up, but has keel rollers too. The boat was well-strapped, and so was the mast. By the way, the tow vehichle, 2002 Chevy Suburban, is in excellent condition and tows heavier trailers smoothly, as well as drove perfectly without the trailer attached.
Can anyone kindly suggest what I might need to check out to stop the vibration? Thanks for the help!
