Broken sheave
Broken sheave
Postby Karl Teske » Mon Jun 04, 2012 8:42 pm
I have a broken sheave, do I replace the masthead or is there a replacement?
Also, if there is a replacement, do I use for a pin through the masthead and sheave?
kayaker
Karl Teske
Postby K.C. Walker » Mon Jun 04, 2012 9:07 pm
Yes, you can buy replacement sheaves. I've used clevis pins but you could use a bolt for the axle. https://www.dwyermast.com/families.asp? ... e=Hardware is a good source for both parts.
Postby GreenLake » Tue Jun 05, 2012 3:01 am
I got my sheaves from D&R Marine. Also used the clevis pins - just felt more comfortable using a smooth surface for the axle.
As the pin or bolt will be stainless and the masthead is aluminum, a bit of TefGel would not be amiss to prevent corrosion.
Postby Karl Teske » Tue Jun 05, 2012 9:00 am
Ok thanks, do you just drill out the original pin that is in the masthead?
kayaker
Karl Teske
Postby K.C. Walker » Tue Jun 05, 2012 10:58 am
Yes you drill them out, the pins are basically rivets so carefully drill off the head and you can punch it through.
Postby Karl Teske » Tue Jun 05, 2012 4:22 pm
Great, thanks for the help guys.
kayaker
Karl Teske
Users browsing this forum: No registered users and 24 guests
