Well, it's time to redo the trailer lights, once again. Dunking the wiring and lights in saltwater does not seem to lend itself to longevity. I'm thinking that it is time to try a light bar attached to the transom.
For those that use this system, how do you run the wiring? I'm thinking that I want to keep all the wiring out of the water this time. I was trying to think of a way to keep the wiring on the boat and not have it too vulnerable. Was thinking I might make the harness detachable on the winch post and run the wire down the mast held on with ball bungees.
Right now I have a hold down (that holds the boat) at the rear of my trailer made of wood that also is the mast support. It would be easy to attach lights to that. My trailer is 20 inches shorter than the transom. So, my present trailer lights aren't at the rear boat. I'm sure it would be safer to have the lights right on the transom. However, is there a law about having the taillights at the actual end of the boat?
Are these light bars that people use legal in most states?
Thanks for any thoughts!
