trailer for a 1967 Oday daysailer
Postby Guest » Sat Aug 10, 2002 1:49 pm
Any recommendations out there for the make or stlye of trailer that is suitable for transporting a 1967 daysailer.
Is it safe to assume this boat weighs in the 575 lb. range? It has just the standard equipment and rigging.
Thanks, walt
Walt (heinw-at-westol.com)
Postby Guest » Wed Aug 14, 2002 12:31 am
I'm interested in same (1969 though) trailer. I called Cape Cod shipbuilding and they sell them, but they don't ship...bad if you live 1,200 miles away from Boston like I do.
From my research you should be able to contact a trailer company near you that can recommend one...most are adjustable as far as bunks (think they're called 'ponnets'?) and keel support go.
One last thought..try Triad Trailers; they have the best propoganda, but I don't know about their trailers.
Tom (tbeames65-at-cs.com)
Postby Guest » Thu Aug 15, 2002 10:49 am
I have an old but sturdy HIGHLANDER trailer for my 1979 DS II, it is a 1200# capacity. Cape Cod Shipbuilding does not have their trailer custom built for the DS as far as I know, if they gave you the brand and model, you could buy it locally from another dealer. However, any good trailer dealer that knows his/her stuff will be able to set you up with a properly sized and adjusted trailer. Someone else mentioned the bunks being called "poppets" (said ponnets", but I assume meant poppets), poppets would be short posts with pads that rest against the hull, these are used on sailboats with keels in place of the bunks.
