CB Gasket replacement
Postby boondox » Sat Dec 05, 2020 3:24 pm
Is it possible the centerboard handle didn’t have a gasket? I’ve pulled the handle and either the gasket is hardcore epoxied and glass in or there wasn’t one there. I’m a first timer with a very new to me DS and was told by previous owner the gasket needed to be replaced to fix the leak coming in from the handle.
boondox
Re: CB Gasket replacement
Postby Fly4rfun » Sat Dec 05, 2020 11:48 pm
I am also new to the daysailer, My DS1 has a gasket. and my belief is all that have the handle do. DR marine has them reasonably, and I have found that Rudy is great to work with, and has a wealth of information. http://www.drmarine.com/default.asp . and welcome.
G.
"Sail Aweigh" 1966 DS1 #2675
Fly4rfun
Postby GreenLake » Sun Dec 06, 2020 11:19 pm
Over time, gaskets can disintegrate . . . I have one on the reverse side as well, and this it what it looked like:
1042
Click to enlarge...
Postby boondox » Mon Dec 07, 2020 12:14 am
Thank you for your responses. To answer my own question, yes, it is possible for the handle to operate the CB without the gasket. Having no knowledge on how the assembly was supposed to look like, I figured the gasket was somehow flush with the trunk or hidden from view. Once disassembled I realized where it should have been. Much drier ride today.
Thanks again for your input.
boondox
Postby GreenLake » Tue Dec 08, 2020 5:26 am
Always our pleasure.
Postby Fly4rfun » Wed Dec 09, 2020 6:46 pm
can you remove the CB gasket and not have a leak ?
Fly4rfun
Postby GreenLake » Wed Dec 09, 2020 10:35 pm
Depends on where the pivot pin is relative to the waterline. That may be different for some boats (e.g. floorboards or not, etc).
Postby Fly4rfun » Mon Dec 21, 2020 3:29 pm
GreenLake wrote:Over time, gaskets can disintegrate . . . I have one on the reverse side as well, and this it what it looked like:
1042
Click to enlarge...
is that a stock configuration or a upgrade
Fly4rfun
Postby GreenLake » Mon Dec 21, 2020 7:38 pm
Methinks it was an upgrade. Something that some DS1 owners did.
Postby Fly4rfun » Mon Dec 21, 2020 8:44 pm
thanks
Fly4rfun
Users browsing this forum: No registered users and 32 guests
