Where and what kind of Ratchet Blocks
Postby bluesman » Tue Jul 22, 2014 10:10 am
I am very interested in installing Ratchet Blocks on my Main as well as my Jib lines.
MAIN: My Main runs from the traveler through 2 blocks on the boom down to the swivel block/upward cleat on the Centerboard truck. Would it be better to replace the big block on the Swivel or to hang one off the boom?
JIB: can someone share some knowledge about what type of block will work for jib lines and how they are installed?
thanks!
Cape Cod Shipbuilding DaySailer
bluesman
Re: Where and what kind of Ratchet Blocks
Postby jeadstx » Tue Jul 22, 2014 12:28 pm
Is your boat a DS1 or a DS2?
Postby GreenLake » Tue Jul 22, 2014 2:07 pm
I use a single Ronstan55 Autoratchet as the forward block on the boom. I leave the auto setting engaged. At the same time I upgraded to FSE Robline Racing Sheet and am very happy with that combination. The Racing sheet is grippy but smooth running.
I usually sail in lighter rather than heavier conditions; by also changing the block at the end of the boom I could increase the overall holding power of the ratchet, but have not found this necessary.
My mainsheet runs from
  • a becket on the block at the back of the boom to
  • a block on the traveler and then to
  • the same block at the end of the boom and then to
  • a block at the middle of the boom and down to
  • the swivel block on the CB trunk.
Depending on whether you do the double purchase at the end of the boom, your sheet loads may be higher.
I have upgraded the blocks on the jib sheet cars with the same ratchet blocks. My jib sheets have a very slippery cover (not a rope originally designed to be used for that purpose) but the ratchet blocks hold it well.
Postby bluesman » Tue Jul 22, 2014 2:51 pm
jeadstx wrote:Is your boat a DS1 or a DS2?
My boat is manufactured by CCSB and is made from original DS-1 molds.
I looked up the Ronstan blocks and there are many options. Greenlake which styles did you use? Any pics of the installation of the jib sheet car?
http://www.ronstan.com/marine/range.asp?RnID=334
bluesman
Postby GreenLake » Wed Jul 23, 2014 3:35 am
Here's a picture of the block installation for the jib. For the main, I use the same block, in place of the forward block on the boom. I simply set these to the "auto" setting and that works for me.
1818
Postby bluesman » Wed Jul 23, 2014 9:25 am
Thanks, perfectly clear in my mind now
bluesman
Postby jeadstx » Wed Jul 23, 2014 1:17 pm
Greenlake, do you use ratchet blocks for the jib sheets as well as the mainsheet?
Postby GreenLake » Wed Jul 23, 2014 3:56 pm
John,
yes. I've had the ratchet on the main and liked it and recently found that I wanted to play the jib sheets by hand and that this was awkward due to slippery rope as well as the loads being higher than comfortable.
So I bought two more ratchet blocks. I had to undo the car's U strap from behind (it's bolted) to be able to fit the strap for the ratchet.
New system works like a charm (I've learned to leave jib-sheets and main sheet rigged all the time, because it's easy to get the ratchets strung backwards....)
Users browsing this forum: No registered users and 115 guests
