Spinnaker Pole
Spinnaker Pole
Postby jblumsden » Mon Aug 17, 2015 7:41 am
What is the correct length for a spinnaker pole for a DS II? I believe all of the mast hardware is in its original stock positions. Thanks
jblumsden
Re: Spinnaker Pole
Postby jeadstx » Mon Aug 17, 2015 11:26 am
It would be the length as one for a DS I. I don't have experience with a spinaker. I use a whisker pole that is adjustable from 4' to 8'.
Re: Spinnaker Pole
Postby GreenLake » Mon Aug 17, 2015 6:48 pm
74" is the class dimension. The pole size needs to fit the sail. If your sail falls within the class measurements, 74" should work.
