How to Route Roller Furler Line to Cockpit on DS2
Postby Curt3000 » Fri Jun 06, 2025 7:58 pm
I'm installing a new roller furler and am looking for ideas on how to route the line from the furler to the cockpit on my 1977 DS2. Especially Placement of fairleads as you route it back.
Curt3000
Re: How to Route Roller Furler Line to Cockpit on DS2
Postby GreenLake » Sat Jun 07, 2025 4:13 am
You need to decide whether you want the line to end on starboard or port. I can't imagine that you'd need more than one fairlead. Try it out with a bit of rope, I bet you need only one, at the very most two, to get the line over to the side of the foredeck and onto the side deck on your chosen side. The angles are shallow, you probably could get away with those ring-shaped fairleads and might not need cheek blocks, for example.
Or you could put a hole in the front of the raised part of the cuddy and lead your line pretty close to the centerline of the boat to some place where it emerges at the top of your cuddy opening. That way you can operate it no matter which side is upwind, without having to sit on the very downwind side, or be forced to tack first.
I used to own a furler on another boat. It did not have much in fairleads, but the deck was flat (no raised cuddy). It went to the SB side, not a bad choice to be on SB tack when you furl, so other sailboats need to give way. Not an issue, of course, unless you sail in crowded waters. I didn't like that particular furler much, but that was because it could get stuck, and the boat was smaller and did not allow going forward to clear anything.
Users browsing this forum: No registered users and 43 guests
